Good morning everyone, is it possible, after importing and overlaying two images with the same magnification factor, to make one of these images transparent or slightly blur it so that the overlaid image is visible? Thanks
if you mean to do that in Rhino, yes, you can import the image and then play with Transparency under Properties → Material:
Thank you very much, I meant to do it in Grasshopper
human has preview node that allows you to load an image and set its transparancy as alpha value or as additional alpha texture
