Hi, (sorry for my googlenglish)
I don’t know if I’m in the right place. I would like to submit an improvement for handling linked files (blocks).
I have been using the insertion of linked files in rhino for some time and I have the impression of having gone to level 2 of the software. This functionality increases the functionality of rhino3d.
However, the interface is “a little dry”.
would it be possible to have the list of linked bocs in numerical and alphabetical order?
Would it be possible to have a color code to materialize the blocks which are not up to date?
Would it be possible to sort by block that is not up to date?
Would it be possible to change the display order of the linked blocks if we do not want the alphabetical order?
Would it be possible to display with a symbol the blocks which do not have an occurrence in the file?
Would it be possible to have a column in the list that gives the number of occurrences used in the file?
Finally, when we update a block and the linked file changes the layers, their names, the order, etc … would it be possible to have in the target file a different color code for the old slaps and not modified which are no longer linked to the blocks so that they can be seen visually.
Finally(2), would it be possible to have a macro which records the master file as well as all the linked files in a specific folder. A kind of “Package” command in Adobe Indesign
best regards
I think many of these are already on the Wish List.
Unfortunately, some will require a major development effort to make possible, potentially starting over from scratch with the Layer code.
Thanks for the suggestions, just the same.
Hi John,
It’s already so amazing to have a listen as a user. The future is yours! Thank you so much.
I am a 3D neophyte, the use of linked files has completely changed my work. PlanC, geometries, renderings, etc … Linked files are more reliable, light and I go deeper into the drawing. This makes it possible to work without an otherwise precious Outliner.
What bothers me the most in Rhino3d is the dificulty of keeping a plot on a plane without having completely irrational projections. I would like to believe that it is a lack of mastery on my part, but these are errors that I have neither in Blender, nor in fusion360. Without really knowing how to describe it, I have the intuition that this is reserved more particularly for certain geometries.
I have one last suggestion: the possibility of changing the type of display per layer.
Apparently the layers seem at the end of the road, unless users have more requests. A lot of software is in the process of evolving them.
last note: your file management on mac is horrible. You have to track down the developer who is a Microsotf phone transfer, give him an iphone …
Otherwise I love Rhino3d
Best regards
UX and insert command: to stay within the Insert command evolution requests. Could it be possible that the path of the target folder remains in memory to facilitate multiple inserts?
