Blocks in Grasshopper
I’m having trouble with what seems like a very simple task.
I have a set of points and I want to place a block (already defined in my Rhino file) on those points using Grasshopper. As shown in the screenshot, I’m using the Insert Block component and it appears to be working correctly in the Grasshopper preview.
However, when I bake the output of the Insert Block component, nothing gets baked into Rhino.
Am I missing something obvious? If needed, I can also attach the Rhino and Grasshopper files, although they’re fairly large. I thought this might be a common issue with a straightforward solution.
How did you bake?
I simply right clicked on it and chose bake, I also tried the simpler way which is grasshopper’s circular floating menu (middle click menu)
I would suggest using the Grasshopper Rhino components
I’m not sure I understood what you said, do you mean the native Bake component? I tried that and got this error:
“Could not load type ‘System.Management.Instrumentation.InstanceNotFoundException’ from assembly ‘System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’.”
I’m attaching my files too
temp.3dm (202.8 KB)
insert block.gh (12.0 MB)
Do you want to keep working with EleFront? If so, I can’t help you.
As I wrote above, you can use the Grasshopper Rhino components.
Your block instance ‘Coniferus’ is not on the origin. Personally I would store the block in a separate file with the geometry located on the origin.
You can place the block and bake like this:
insert block mrtn.gh (14.3 MB)
temp mrtn.3dm (659.4 KB)
I ran your script with the eleFront component myself and it worked just fine, so I’m not sure what could be happening on your end:
elefront_bock_bake2
You can also use the Bake component from eleFront (not the native one) :
I would also suggest updating to the latest eleFront, the “InstanceNotFoundException” has been fixed.
Thank you so much, I didn’t know the location of the block is relevant for orienting it and as for the baking issue, apparently it has to do with the version of my .NET
I think there was something wrong with the version of my .NET
