I have a model that I bought that has blocks. I would like to edit it, but getting message
:“Unable to edit non-uniformly scaled block instances” Is there a way find the controlling block?
yes is it possible.
- take the block objectname
- insert (_insert) a new instance of block objet in your model
- edit the new block .
good luck
That work perfectly
Thanks
your welcom
Hi SMC2,
I have one model with Hundred instances non-uniform scaled and i simply need to change the material inside the block. DO you have a solution to me too that of course i can’t reinsert all of the instances?
Thanks,
Roy
Hi Roy - you should be able to just insert a new instance - which will be uniformly scaled (1:1) - and BlockEdit that one to change the material. That should then update all non-uniformly scaled instances in your document.
Does that work?
Thanks both,
Roy
