Blocks and User Text Fields to drive parts tables and drawing callouts?
Has anyone ever tried to use Blocks and / or User Text Fields to link a drawing parts table to the call-outs in the drawing, dynamically?
I’m in the middle of producing several 2D drafted assembly drawings. The columns in the parts tables are for:
  1. The call-out letter call (has to be by letter, not number, with no I or O allowed)
  2. Quantity
  3. A written description of the part
  4. Part number. This is the primary reference.
  5. Catalogue number. This is basically a cross-reference to another parts numbering system. It is permanently linked to the Part Number
Nothing too arduous. The hassle I get is when a new part is introduced. The aspiration is always to have the parts table stacked in ascending Part Number order. So if a new part is introduced and its part number is in the middle of the table, all of the call-outs north of that have to be updated, both in the Parts Table and also in the drawing space. At the moment, that’s a manual process. It’s very time consuming and also prone to errors.
I’ve had a look at the byRhinoGadget _AddCallouts. It’s very clever and does a good job but so far I can’t see a way to get it to give me what I’m looking for. Also, it’s not dynamic?
So - is there a better way? I wondered about creating a set of user defined Text Fields for each part, perhaps as the Parts Table:
  1. Pt.No.
  2. Pt.No. + call-out
  3. Pt.No. + Cat. No.
But that would create a lot of User Text Fields (Parts lists can run to 90+ items). Would that slow the file down?
Here is a quick table that can be generated from blocks, wouldn’t be too much of a stretch to add Callouts
Many thanks. I think I’ve read that thread before but I will have another look. I’ve got no experience with Grasshopper but I see there’s an .rhp
In your view, what is the best way to drive this? Create Table with each text a user defined Text Field, then use Blocks for the drawing call-outs linked to the relevant Text Field?
I’m trying to form an idea of the best workflow in my head, to link the parts table to the drawing content. If I could work out the neatest approach, I’ve a feeling hooking things up would be easier. Something like an Excel UserForm comes to mind, which would automatically create Text Field names for the values, with the Part Number as their “stem”. If the output of that were used to populate a parts table like the one you’ve just linked to, and editing any of the values in the table also updated everything else that’s called in the drawing space, it would make edits a lot easier.
If I try to drive things the other way around - namely, build a parts table from what’s in the drawing / Layout space - then I have to contend with the number of instances to check, edit and update. But Blocks could make that easy (or easier, anyway).
And it all needs to be dynamic…
