I have a question about the behaviour of the blocks in rhino.
Is there a way to change the layer of the block so that it applies the properties of the layer to the content of the block itself?
for example with AutoCAD if I draw the lines inside the block on the layer 0 when I change the layer of the block the lines inside the blocks will be printed as if they belong to the new layer.
Thanks in advance
