Blocks and clipping planes issue
Hi everyone,
I’m having problems with this simple file. It’s a cabinet turned into a block containing four blocks inside.
I’m experiencing a graphic issue when using clipping planes through blocks, as you can see in the image below the section is not showing the cutting fill. If I copy the block and run _explodeblock the problem disappears.
BlockClippingPlanes.3dm (3.4 MB)
System.txt (3.1 KB)
this is well known bug of rhino
Yes, I know. Just want to bring attention to it, showing a simple file. If you create a box and turn it into a block it works as expected.
Steve recently fixed a bug for the fills, but there is still a bug open on the curves.
Thanks John, I hope he can solve the contours problem too, it would be a fantastic improvement.
