BlockRanger mesh generator Version 1.2
BlockRanger now has Version 1.2 of its easy-to-use interactive volume mesh generation plug-in for engineers.
BlockRanger converts Rhino 5 solids into blocks of high-quality hexahedral (brick) elements. Use with most engineering analysis packages that require hexahedral meshing and a strict control of element quality, spatial distribution, and orientation.
Features
  • Construct and mesh complex models using the advanced tools available in Rhino. Then use BlockRanger plug-in for Rhino to volume mesh FLAC3D zones or 3DEC blocks.
  • Interactively use BlockRanger to partition your model into an assembly of 4-, 5-, or 6-sided solids.
  • BlockRanger’s meshing applications range from fluids and structures to biomedicine and geosciences.
  • BlockRanger is easy to learn and to use. If you know Rhino, you already know how to use BlockRanger!
More information …
Posted Oct 03, 2016 by Sandy McNeel on Rhino News, etc.
