BlockManager - see Properties of linked blocks' blocks?
Hi All,
I have a bunch of linked blocks that contain nested block instances themselves. I can see and change the properties of the main linked blocks, but when I check the box “show reference definitions”, properties of these are not accessible (button greyed out).
I understand that changing the properties of the linked blocks’ subblocks may not be possible without editing the original files, but we should be able to at least see their properties, like description, URL Tag, Hyperlink etc… Maybe the Properties panel can still open but show everything non-editable?
Is there a way currently access this info without scripting?
thank you,
–jarek
Hi Jarek - not that I know of, but I will add this to the heap - I do not know what is possible.
