BlockManager columns
RH-79684 is indeed fixed in 8.4.24016.19001, thanks!
Another one (if you can call it a ‘glitch’):
  • The new Block Definitions panel doesn’t seem to have column headers (like the Layer panel), so the distance to the count column cannot be set (which is pretty wide).
Thanks!
Edit: same goes for the new Properties panel.
In R7, it was possible to grab the input field border and adjust it:
since this is “another one”, I’ve put it in another thread…
That’s what it looks like here:
RH-79819 Properties: Resize columns
Sure, thanks! (Yes, not too much stuff in one thread)
Ok, strange… then mine must be broken. Definitely no header bar here. Something I can try?
Hi Eugen - does it change anything to float/undock the block manager panel and reszise it?
I have never seen these column headers either. Maybe this is a windows only feature ?
No change:
In my scene there were plenty of block definitions. I checked if it helps if there are only a few - same issue.
I’m on windows.
Ok then I guess it is a 8.5 feature. I’ve seen blocks sorting mentioned with 8.5 elsewhere
Edit : here
