Blockedit doesn't function (unknown command)
hi, guys.
i just find blockedit command doesn’t work, the rhino says “unknown command”. which is i assume it happened because i’ve installed a plugin “blockeditnew” but doesn’t work, a few days (until today) after i installed the plugin, the blockedit command doesn’t work.
i tried double clik, type command, and click the icon from block panel still doesn’t work. please if you have any suggestions to do, i will try it
Hi -
Have you tried to repair the Rhino installation from the Windows Control Panel?
Hello, Wim
yes, i did the rhino repair.
thank you
