I’ve worked a lot in rhino 5 with blocks and loved the feature that when editing a block everything got greyed out and put in the background, resulting in the fact that i could see all the elements in the block from any view. In rhino 6 when i use block edit the greyed out elements dont get sent to the back and i always have to hide all elements and then blockedit so i can view my block elements from all angles.
Is this the new way that block edit works or is it just a setting i must check or uncheck?
Thank you
