Block strangeness in WIP
I’m experiencing a similar issue when using WIP build (7.0.20252.11325, 9/8/2020). All the blocks wholly visible in the viewport disappear when I execute a move/rotate/gumball move/gumball rotation. This behavior is limited to the perspective viewport, and I’m experiencing it in wireframe, perspective, rendered, X-ray, and ghosted display modes, but NOT in technical, raytraced, or derivative views.
This issue occurs sporadically, and I can’t get 100% reproducability. It seems to be a function of zoom distance/camera distance to target. The below file seems to exhibit the behavior when the following steps are executed:
  1. Select a block
  2. Hit esc
  3. rotate/zoom/pan
  4. Blocks disappear until they are re-selected (they are still selectable)
The attached example file exhibits this problem for me at the saved view. Hopefully the results can be reproduced if a block (one of the L shaped polylines) is selected, the user hits esc, and then zooms out immediately.
Display Issue Test.3dm (657.7 KB)
Fortuntaely working in one of the other view modes is an ok-work around for the time being.
Split and moved to a new topic in the appropriate category.
Hello - so far OK here… can you please run the SystemInfo command in Rhino and copy/paste the results here?
Rhino 7 SR0 2020-9-22 (Rhino WIP, 7.0.20266.15205, Git hash:master @ bdd59bed042c78c1a0b1b28b924b4abe7d6c0d8e)
License type: Commercial, build 2020-09-22
License details: Cloud Zoo
Expires on: 2020-11-06
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce RTX 2080 SUPER (NVidia) Memory: 8GB, Driver date: 8-12-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.06
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-12-2020
Driver Version: 27.21.14.5206
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
D:\Programs\HECSTAB\HerbertABS.Plugins.Rhino.rhp “HECSTAB” 0.0.0.0
C:\Program Files\Rhino 7 WIP\Plug-ins\Commands.rhp “Commands” 7.0.20266.15205
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.20266.15205
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.20266.15205
C:\Program Files\Rhino 7 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.20266.15205
C:\Program Files\Rhino 7 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.20266.15205
C:\Program Files\Rhino 7 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7 WIP\Plug-ins\Displacement.rhp “Displacement”
Hope this helps.
Hello - thanks, can you please try disabling the above plug-in in Options > Plug-ins page, then close and re-open Rhino and see if the problem persists?
Yes, I just noticed that when I posted the system info and retried it with it disabled. Resolved the issue, thanks! I’ll go have a chat with our sister company’s developers…
Though if you have any feedback I can pass to them to prevent this from happening as they develop that plugin, it would be beneficial so they don’t accidentally ship that plugin eventually with this error.
Thanks again!
Hello - I do not have anything to contribute myself that might help resolve the problem but of course the developers can contact us and get help -
https://discourse.mcneel.com/c/rhino-developer/3
