Block Plugin Renderer Development Kit UI
In the Plug-ins section are you unable to load it manuall?
Also ensure there is no virus software blocking it.
I have thesame probleme,does anyone have a the solution?:cry:
Hi @wudiagu,
Did you try the tip above? Of so, then can you run the SystemInfo command and post your results here?
– Dale
What tip above? I don’t see anything.
Hi @antons9871
and otherwise:
