Block on every point
I’m unexperienced with grasshopper, but I think this one is ideal for it:
I have a grid with 2000+ points. on every point I need the same item. is there a way to multiply a polysrf on every point with on or two clicks? the point grid is random, so array doesn’t work.
looking forward for your replies!
Albert
Hi Albert -
You reference the Rhino geometry, an origin point, and the point collection. You create a vector between the origin point and each point in the collection. You move the original geometry using those resulting vectors.
Tanks Willem,
can I ask for the file?
thanks a lot,
Albert
Hi Albert -
Copy to points.gh (3.8 KB)
thank you very much, you really helped me out here!
But you didn’t post one. :frowning: Orient also comes to mind.
