Block not responding
I’ve downloaded a cad block of a car to use in my project. I turned it into a block and now the object has gone black and I can’t edit the block. This happened before with a window n the only way I could get rid of it was by undoing but I’ve since closed and opened the program so I can’t do that now. Any ideas on how I can remove the unresponsive block or make it responsive again?
Hm - not sure what this means - it is possible the object is locked, so Unlock will get it back to normal. In the even you Lock-ed and not Block-ed…
Just tried that. It’s says there’s no locked objects. I also tried to just delete the block and it won’t let me, saying “cannot delete reference objects that use this instance definition”
Hi Hachibi -
Please provide both the output of the Rhino SystemInfo command and a 3dm file that is misbehaving on your system.
