I think an ObjectTable.ReplaceInstance is currently done on normal object level.
But I think we need to loop through all objects including IdefObjects?
Being able to import nested blocks using the -insert command while maintaining the block structure for nested blocks would be a game-changer for us. Really hope you can find a solution, @dale@mary ! ! !
Hi Wim.
I made this short video showing the different bewteen using the Insert with pop up windows and the -insert command line option.
With the -Insert it is making a block called “X 01”. As you can se in the video i have the “ResolveConflict” set to “Redefine”
Can you recreate this?
