Block explode problem V6 vs. V7
The blocks come in different in V6/V7.
Also on _Explode they behave different.
Open this DXF in V6.
Block.dxf (42.5 KB)
Select a block (is circle, point).
_Explode
Ok, is as expected.
Do the same in V7.
Select a block (is circle, point and text).
_Explode
What can we do to have the same result as in V6?
Hi Charles - thanks, I see this.
RH-63513 ExplodeBlock: Don’t lose the text value
Hi @Charles,
Do you know where this .dxf file originated from? AutoCAD?
EDIT: I got this when trying to open in AutoCAD 2021.
Improper table entry name ATRIUM HOCH on line 42.
Invalid or incomplete DXF input -- drawing discarded.
– Dale
I’ll try to find out the file source.
DXF comes from:
Hilti Totalstation POS15 https://www.hilti.de/c/CLS_MEA_TOOL_INSERT_7127/CLS_CONSTRUCTION_TOTAL_STATIONS_7127/r4847
