When I am doing an in-place block edit I wish I Cplane would re-adjust to show the block origin.
I like that idea! At least as a sticky option/checkbox in the BlockEdit dialog.
+1.
-j
Yeah something that you could turn on/off would be good.
@JohnM Did you see this?
Hi Dennis - do you mean, show the current CPlane with the origin at the block insertion point? If a block instance is rotated, this could be misleading, so I am not sure if I’ve got it right - perhaps a CPlane reoriented according to the block transform ?
Not exactly. I mean show the CPlane with origin as if you were looking at the block in an export file, so if the block is rotated the CPlane would show rotated as well.
