Is is very common to redefine a block (when updating its geometry). A workflow, of explode, fix, redefine is common. The block definition dialog block (for the Mac version) does not have a dropbox with possible block names. This dropdown list should be added. Furthermore, it make a lot of sense to suggest as default the name of the last block that was exploded. If the block was redefined, then this default should be set to null, so if another block is defined, the user will have to enter a new name.
On 23 ביוני 2014 22:00:04 GMT+3, marlin steve@mcneel.com wrote: marlin June 23 Thanks for the report. The name field will be include a drop down menu with the existing block names in the next WIP release. To respond, reply to this email or visit Block Definition dialog in your browser. Previous Replies yuval June 21 Hi! Is is very common to redefine a block (when updating its geometry). A workflow, of explode, fix, redefine is common. The block definition dialog block (for the Mac version) does not have a dropbox with possible block names. This dropdown list should be added. Furthermore, it make a lot of sense to suggest as default the name of the last block that was exploded. If the block was redefined, then this default should be set to null, so if another block is defined, the user will have to enter a new name. To respond, reply to this email or visit Block Definition dialog in your browser. To unsubscribe from these emails, visit your user preferences.
