I am working with some models exported from SolidWorks. As a consequence, when importing those models into the Rhino, I have a situation when every detail is placed in a separate block and if in SolidWorks there were assemblies and subassemblies – those details in Rhino will be in some nested blocks. But I need to work with separate details ( here – separate closed polysurfaces).
I have made a script for interactive Rhino like this:
import Rhino
def decompose(objs):
surfs =list()
for obj in objs:
if obj.ObjectType == Rhino.DocObjects.ObjectType.InstanceReference:
decompose(obj.GetSubObjects())
elif obj.ObjectType == Rhino.DocObjects.ObjectType.Brep:
surfs.append(obj.Geometry)
if surfs:
[Rhino.RhinoDoc.ActiveDoc.Objects.AddBrep(brep) for brep in Rhino.Geometry.Brep.JoinBreps(surfs,0.1)]
doc = Rhino.RhinoDoc.ActiveDoc
objs = doc.Objects
decompose(objs)
for obj in objs:
Rhino.RhinoDoc.ActiveDoc.Objects.Delete(obj)
doc.Views.ActiveView.Redraw()
But this script will not work when I run it in Pycharm using rhinoinside library (the idea here is to use Rhino in a headless mode.
I would be very grateful if you could recommend me how to rewrite this code so that it will work in Pycharm. As far as I see – the main problem is that in Rhino we usually work with RhinoObjects and when working in a headless mode using rhinoinside – we get some File3dmObjects. And those two classes have different methods and attributes.
