Block commands from GetOption() options
I have code that looks like this:
	var gopt = new GetOption(); // from Rhino.Input.Custom
	int disableIdx = gopt.AddOption("Pause");
	int enableIdx = gopt.AddOption("Unpause");
	int toggleIdx = gopt.AddOption("Toggle");
	gopt.SetCommandPrompt("Action");
	gopt.Get();
	// PROBLEM
	// we never get here if we press Pause or type Pause as the option
	Result rc = gopt.CommandResult();
	if (rc == Result.Success && gopt.Result() == Rhino.Input.GetResult.Option)
		CommandLineOption clo = gopt.Option();
		// here some useful code
	return Result.Nothing;
It appears that using the option Pause doesn’t work since there is already a command called Pause. Is there a setting on GetOption() that prevents commands from taking precedence, or how can I ensure I can use option names that look like existing commands?
A similar problem happens when I use the string Lock (for Lock and Unlock as options).
Answering my own question here.
The fix is to use
gopt.EnableTransparentCommands(false);
Scratch that. After a full rebuild I still see Pause breaking my command, even with gopt.EnableTransparentCommands(false).
