Hi All,
I work with a lot of geometry that is imported from Revit, which seems to always leave me with a huge number of blocks. I suspect this is to do with the export/import and the way Revit represents objects, but I don’t use Revit myself, so couldn’t say more.
Some blocks represent complex objects, and need to stay as blocks. But many many blocks only contain a single piece of non unique geometry. eg, every single identical paling on a fence comes in as a unique block. if it were one block with multiple instances, that would make sense - but they come in as hundreds of separate unique blocks.
Can anyone think of a way to select all blocks that 1) only have a single element in them, and 2) only have a single instance? so that these blocks can be exploded without exploding every block?
Cheers
Ben
