Lets say I imported a CAD plan that has a bunch of blocks nested in blocks- is there an easy way to make all the contents of a block uniform in color and layer? Currently, when I change the layer of the block, it does not change the layer of the sub-block geometry. And when I want all the contents of the block to change from a custom color to matching layer color, it does not change the that property for all the sub-blocks.
I’m trying to simplify the model so that all the many plumbing and mechanical layers are all consolidated onto one, and so that the colors are the same too.
To get the color changing behavior you described, you’ll need to define (or redifine) your blocks a little differently.
The color property of the object or the layer the objects are on needs to be set to “By Parent” instead of By Layer.
Coming from a DWG, “by parent” is not the default way that blocks work. I guess I still have to go in one by one and change the properties to “by parent” then? There is no brute force way to change the properties of all sub-blocks?
The other thing is that I am able to double click into a block, but cannot double click into its sub-block. The block names are in Japanese, so it’s kind of hard to identify it in the blockedit window.
Correct.
AutoCAD uses a special color and layer to get the color and line type changing to work.
Rhino uses the By Parent property to do a similar but more flexible thing.
you can also see this script from other discussion - it will let you set properties byParent, ByLayer or even change all in-Block objects Layers or per-object Display Mode:
I think I got “ByParentize” to work, but what is still causing me problems is the layers of nested blocks. I am trying to delete a layer, but Rhino says that there is a block/objects on that layer. When I do “select objects,” nothing is selected because the object is in a nested block. Is there anyway to delete a layer and move the contents to the default/current layer?
you can use the above script to move all your blocks/nested blocks objects into specific single layer, so you can delete/purge whatever you don’t need from layers panel.
