Blending Solids/surface advice
I have two aspects of a model that I need to blend/transition smoothly. If anyone could advise on this I’d be very grateful. Model is attached. I have a bezel that needs to blend into the texture of the surface of a box.
BlendSolids.3dm.zip (1.1 MB)
I would cut out the space for the bezel, and then build the bezel so that it blends as required. Sweep2 would be one of the commands I would use.
