Hello! I’m trying to model a ribbed surface texture that flows across this concave double curved surface and fades out evenly towards the edge (something like the reference photo attached) but I’m struggling to find a successful method. Any tips for achieving this purely in rhino would be brilliant.
You could model washouts, like on a car, with the trim-and-insert approach. By moving the centre CVs of the inserted curves in the normal direction, you determine the rib’s depth. I just futzed it; you’d have to trim from the correct angle, so the width is always equal.
For completeness, or in case you want to get a job at LVMH Rimowa (then please revive the original “Topas” range), here’s a more controlled way how to do it with G2 continuity.
