Could anybody advise me on the best approach to the following surfacing challenge?
I’m modelling an aircraft fuselage in Rhino 8. I have two overlapping lofted bodies: the main central fuselage and a separate body representing the external intake fairings.
I’ve adjusted the loft profiles to get the surfaces as close to the desired shape as possible, but I’m now struggling with how best to achieve a clean, smooth transition between them.
As shown in the following image, there are two main objectives:
Smooth rear transition: Towards the aft end, I want the fairings to merge seamlessly into the central fuselage, ideally with G2 continuity and clean Zebra/EMap reflections.
Gradually disappearing crease: Towards the front, I deliberately want to retain the defined shoulder / crease. Moving rearwards, this crease should progressively soften and eventually disappear into the smooth rear fuselage surface.
The overall effect I’m aiming for is for the intake fairings to emerge naturally from the fuselage, with a pronounced shoulder at the front and a seamless transition at the rear.
I’ve experimented with splitting the intersecting surfaces and using BlendSrf, but haven’t yet achieved a satisfactory result.
What’s the best surfacing strategy for this kind of task? Should I be working with the two existing lofts, cutting away some areas and then constructing local blend surfaces, or would a different surface arrangement be more appropriate?
I wouldn’t model any more than is needed. Just model one side a then use matchhsrf to connect the cowl to the tail section. Mirror will make the other side.
Thanks Jim, that’s a great help. The MatchSrf approach looks like a good simple solution for joining the fairing to the rear fuselage section.
The remaining challenge is getting the shoulder to gradually fade away into the fuselage. I’ve highlighted the area in the Zebra analysis where the reflections bunch up and change direction.
Do you have any suggestions as to how could I achieve a smoother transition here while retaining the defined shoulder further forward?
Hi David, I’m designing an RC jet which is not based on any other aircraft. I’m using cross sections that match to upper, lower and plan left, plan right curve profiles for the central fuselage and then I created the fairing loft using sections that looked right against the central fuselage.
The goal is to model it in rhino including bays for electronics and then spliting it into 50mm longitudinal slices to get the cross sections profiles that will then be used as templates to hotwire cut XPS foam stations that will be glued together.
It’s a good question, I don’t really know how good my surfaces need to be to end up with a nice result. I’m guessing not class A because ultimately once all the stations are glued together then I will be sanding, filling and fibreglassing the airframe.
