Hello, I am trying to blend all the open curves together (in the gaps) to achieve a single planar curve. However, I find that the blend curve is always only produced on one side and it gets problems when I try to create the blend on the other side (even when trying to flip curve etc). May I find out what I am doing wrong?
I’m avoiding attaching the definition as the file is very big (can’t really internalize data)
The attached screenshot of the grasshopper definition shows the side that is successfully blended.
Try flip curves for the other sides
I already tried that but it doesn’t seem to be working
Bumps.gh (51.7 KB)
Okay! I managed to delete the other parts of the definition. Could you help me to see what I am doing wrong?
Try with shift list, and you don’t need Graft in output A and B
Bumps_re.gh (49.3 KB)
Hmmm I tried shift list, but there was no change in the appearance (still connected to the wrong points)…
Did you open the file attached?
Oh! My bad I didn’t realize there was a file attached. Thank you so much - really appreciate the help! Idk why shift list didnt seem to work when I tried it on my own the other time.
Maybe you used graft for output A and B
