BlendEdge fail
Hi @pascal,
below is an example where _BlendEdge command fails with a radius of 3. It works with 2 and 4 but not 3. I thought all good things are 3 but i may be wrong.
BlendEdgesFail.3dm (57.1 KB)
_
c.
Hi Clement - I see that, thanks - for now, DivideAlongCreases > SplitAtTangents=Yes will let the blend work correctly.
https://mcneel.myjetbrains.com/youtrack/issue/RH-53208
Hi @pascal, yep. I haven’t mentioned that i deliberately made the extrusion from one surface to have it easier to build a mesh for FEA. I need to control mesh density using a progression which only works if i have the blend in a single piece and no edges inbetween. I’ll merge the blend pieces by hand to get this working…
_
c.
Got it… I’ll add a comment.
