hi @chuck, all,
Please take a look at this uncooperating tool towards more work efficiency. It can do the bled, but only one at a time, not 2 at once:
will_it_blend_9mm_gf_210130.3dm (1.8 MB)
What’s this? Part of the SlowBlend Movement?
G
hi @chuck, all,
G
Hi Gustavo - Thanks, I’ll have a look…
@gustojunk - there is something about that object - if you Explode it then Join you get your speedy workflow back - I will see if I can figure out what is amiss.
I couldn’t.
RH-62577 FilletEdge - no trim, then trim
C’mon @Gusto, you know full well that extreme left and far right at the same time doesn’t blend well.
// Rolf
