BlendCrv when using the Point option:
Spurious continuity shown in the Adjust Curve Blend panel for the point end of the blend.
For the point end of the blend curve the continuity shown may be Tangency, Continuity, etc even though only Position continuity is appropriate. This level cannot be changed. The level shown appears to the level when the command was last executed. Presumably a display problem because the command otherwise works properly.
This occurs in V8 and V9 WIP.
In V7 the continuity column for the point end is greyed out.
Example:
Command line history:
Command: BlendCrv
Select curve to blend ( Edges BlendStart=CurveEnd Point Edit )
Select curve to blend ( Edges BlendStart=CurveEnd Point ): Point
End of curve
Select control point to adjust.
