Blend two surfaces together
Hello!
It’s probably been answered and in a very simple way, but for some reason Im unable to blend two surfaces seaminglesly. All i need to do is to join to surfaces together. Since one has fillet edges applied, it doesnt let me blend.
Im included the reference - an xray machine head
xray machine.3dm (8.8 MB)
you can not blend surfaces together when they are closed, either explode the surfaces then delete the faces or use subselect (ctrl shift left mouse click) then use BlendSrf for example.
also embedding such tiny surface where you could simply have one continuos is a very bad practice that will throw up many issues, maybe consider rebuilding that entirely.
also please check a few tutorials on the basics of rhino and modelling.
Thank you!
I appreciate you taking your time
