Blend Surface
Note you can add shapes in BlendSrf to true up isocurves.
Ain’t no one got time for that.
Right…
nice trick!
Now that I have practiced a bit a more I really do like using the pipe and adding shapes to refine the blended surface. I’m just curious what the difference is between offsetting a curve vs using the pipe. I notice that the pipe method yields a more desired result. Both ways work really well though!
I’ve used offset curves on surface before. The whole pick direction thing is a total pain. I just find pipe faster and easier to spot continuity breaks with.
totally user preference, same same result. I use both methods depending on the desired outcome.
