I created a BlendTexture with a “color-one”, a “color-two”, and a “blend-texture” texture set. The blend texture, which acts as a mask between color one and two, interpolates between the two.
Is there a way to customize the interpolation mode? I think it is set to nearest by default, but I would like to use linear interpolation.
Can you share a simple file that shows the issue you’re trying to solve? From your description, my guess is that maybe the blend texture map itself could be edited to help. There are some output adjustment settings for the texture but nothing that determines the interpolation method for the blend that I know of.
