Blend Curve with Same Profile
Is there a way to blend curves with the same plan?
When I blend the two sets of curves, although the original curves have the same plan, the blended ones do not.
How should I achieve the target without manually manipulating the control points afterwards.
Thanks a lot!
Ian
draw the first set of curves.
then use _shear for the second set.
post a file if you need more info - kind regards -tom
