Black in Rendered display mode
I have the same problem. After I updated display adapters AMD Radeon ™ R5 M330, it turned out all black in the rendered mode. Normally it should look like this:
but unfortunately it looks like this:
My display adapters:
When I deactivate AMD Radeon, then the rendered mode looks like this:
However, it still doesn’t reflect what it looks in the first image:
This is RhinoCeros 5.
Could you please help me?
Best regards,
Pinar
Hi -
I’ve moved your post to a new thread as it looks like you are running on Windows, not on Mac.
Which Service Release of Rhino 5 are you running and can you please post a screenshot of the Rhino Options > View > OpenGL page?
@aksupi
  • Is this a laptop or a desktop?
  • How many screens are you running?
  • How are your monitors connected; directly into the GPU slot or using a hub or docking station?
Please run the SystemInfo command in V6 and post the results along with the answers to the questions.
Thanks
Hi again,
I don’t know which service release of Rhino 5. From where can I learn?
Here is the openGL page:
Thanks,
Pinar
Hello Mr. Brock,
  • It is a laptop.
  • I have two screens running, one is my laptop’s, the other is a DELL monitor.
  • They are connected with an HDMI cable.
SystemInfo command does not work in V5 and I don’t have V6…
Hello Mrs. Pinar
Can you check the following settings from the Options tab ? One possibility could be the following. Can you re-introduce the materials introduced to the objects?
You are running a very old computer with an unrecommended, under powered display adapter, with an old driver.
Your best option is a driver update;
Use these instructions to update the driver:
Use this driver from 23 October:
https://downloadmirror.intel.com/29971/a08/win64_15.40.47.5166.zip
If you’re serious about running Rhino, please consider replacing this laptop with a new computer that meet’s Rhino’s system requirements:
Any luck?
Dear Mr. Cam,
I don’t have any option as you see:
I checked, all render related options, I couldn’t find anything like that. Mine is V5.
@John_Brock was correct.
Best regards,
Pinar
Dear Mr. Brock,
Thank you so much for your help. I updated the driver as you described and now I can see the rendered mode perfectly. I also bought a new computer as you recommended.
Best regards,
Pinar Aksu
Hi John,
I’m also having this problem of my viewport going completely black when I enter render mode, was that driver you posted earlier recommended specifically to the person you were talking to?
These are the direct links to driver sites I routinely give out:
You have you manually look up your GPU model to find the right drivers.
For V5 and V6, you man need to manually make your non-Intel GPU “Primary”:
Some older Intel GPUs require this:
