Bizarre cursor looks like Paris street sign
Curious cursor turning up in Rhino 5 when I try to draw a polyline. The cursor is a red circle with a diagonal diameter bar. Looks like a French street sign that signifies Passage Forbidden, or no access.
Sure enough, the polyline cannot be drawn. How do I get things back to normal?
thank you for your insights. Michael
Hello - is the view edge-on to the current construction plane?
Thank you Pascal. Yes, I think you are right. I was working in the Perspective view. When I switched to the Front view, the warning cursor (or whatever it is) disappeared, and I was immediately able to draw a polyline with a normal crosshair cursor. Thanks again. Michael
I would have said; an “International Road Sign” :slight_smile:
