Bind surface to CPlane
I am looking for functionality similar to Levels in Revit whereby multiple objects can be stretched or compressed by moving a Level they are attached to. Very useful for architectural modeling to adjust height between floors, etc.
Is there any command comparable in Rhino that can be used to bind object surfaces to a CPlane so that attached objects change shape as the CPlane is moved?
Are you using blocks?
Thanks for that!! I understand how blocks can support resizing of architectural members. I’m a couple of weeks into learning Rhino. I’ll test a workflow to convert structures to blocks if I face a resizing issue.
