The first time you drag the script into Rhino viewport, it remembers its location on your HD and also adds command alias “ToggleSelectionHiglight”, that’s all there is to it in terms of the installation.
You can see its location in Options > Rhinoscript under “Scripts files to load when Rhino starts”.
Is there any way to toggle the selection highlight on Rhino for Mac? I looked into it, and .rvb files are not (and likely won’t be) supported on the Mac side.
Is Python a possibility? Granted, I’m not a coder, so I wouldn’t know what to do with Python past copy and paste.
EDIT: Sorry, I missed the comment above with the exact script to do this. I created a button that runs this script, and it works perfectly! Thanks clement and Jarek!
Did you try to first save the script on your HD, then drag-and-drop into Rhino which should enable the “ToggleSelectionHiglight” command? If you just run the script directly it may not work. Please let me know.
Hi Jakob, clearly your 50 days+ total read time of Discourse is not enough (I have only 24 days and I thought I spent too much time here already…)
Glad it helps, I use it all the time. It is a per-display mode setting but not exposed to UI as I guess it can do some damage for inexperienced or forgetful users. But agree, a check-box in Display Panel for this would be nice.
After opening the plug-in function, the selected sub object can’t see anything. It’s also a disadvantage. As long as it can be turned off and the line behind it is not displayed when it is modified and moved, the official should directly add a switch to turn off the back line display in the software option
@Jarek@pascal Thank you Jarek! This is so necessary! please introduce this as a standard rhino component. I use it with CurveBoolean selecting internally bounded outlines from overlapping closed line work. It’s amazing to just create new 2D shapes from overlapping “grid-work” and shape build. Without the ability to toggle the selection highlight, you are stuck guessing which selections have been made… Just a use case example of how this amazing little script is a useful work around for now until team Rhino decides it can add this like hiding and unhiding grid and coordinate axes.
