There is a method Binarysearch in Rhinocommon which I dont understood!specifically the Icomparer thing, I dont get it! can some body explain how does it work?May be with an example!
That should be much faster than normal linear search I suppose
There is a nice description in the Rhinoscript101 Primer - on pages 78-80…
HTH, --Mitch
IComparer defines a function that is used to compare the items in the list for sorting purposes. There should be quite a few articles on the internet about this. Just search for “IComparer C#” and you will get a bunch of useful hits.
Here’s a good place to start if you want to use the Microsoft documentation to get started
http://msdn.microsoft.com/en-us/library/4ba2bttb.aspx
Here is a simple example that might be helpful:
def test_system_array():
# Class that implements IComparer interface
class MyComparer(System.Collections.IComparer):
def Compare(self, x, y): return x.CompareTo(y)
# Array to sort
array = System.Array.CreateInstance(str, 6)
array[0] = "Pachycephalosaurus"
array[1] = "Amargasaurus"
array[2] = "Tyrannosaurus"
array[3] = "Mamenchisaurus"
array[4] = "Deinonychus"
array[5] = "Edmontosaurus"
# Sort ascending
System.Array.Sort(array, MyComparer())
for i in range(array.Length):
print array[i]
# Search for something
idx = System.Array.BinarySearch(array, "Deinonychus")
print idx
Thanks guys,
That was very helpful,I would try to test it myself see if I can use it or not .
Cheers
