Bifurcation of vertical axes
Hi! I am having some trouble on splitting vertical axes to produce a bifurcation several times. Here´s the deal: I have a horizontal axis that is divided into an amount of points. On each of them, there is a vertical axis that is divided by a variable amount of points that determinate the parameter where the axis should bifurcate each time.
This bifurcation, actually, implies that the axis splits and moves, its not like a branching bifurcation that tends to rotate the segments.
I uploaded a pic explaining this step by step and showing the final result im looking for. I undertand that this is a matter of iteration, but i would like to avoid using hoopsnake or that kind of components, as it makes more complex the lists im working on and i lose the control over the definition.
Maybe I’m not organizing the geometry properly or thinking the order of the steps right. Does anyone have an idea?
Welcome @azulisi,
Wow, this is a very nice, exemplary presentation of your problem! Would you be interested in a scripted solution (i.e. Python), or are strictly looking for a vanilla Grasshopper approach?
Interesting problem
it looks like a bit kirigami
https://www.grasshopper3d.com/photo/kirigami
“exemplary”? With no code or data posted? I disagree. I was lost at “distance Y between splitted segments of axis”. And while @azulisi states that “I understand that this is a matter of iteration”, he rules out using Anemone (forget about Hoopsnake!), so it’s likely that Python won’t do either, eh?
Hi, thank you for your concern!
I think i prefer to find the solution in grasshopper because I’ve never used Python before. For the kind of excercise I’m doing, I really do need to have a total understanding of the strategy that I’m using to organize the geometry, also because i will be re-structuring the definition in the future to compose bigger and more complex thing.
I’ll upload the definition i wrote. The steps that i explained above are gouped in red and i added a panel in the end with a couple of notes. I know it is a little complex, but i hope it to be useful! In case its not, im really interested in other ways to solve it.
Thank you!
Bifurcation of vertical axis.gh (71.0 KB)
