Bézier/Bspline curves and surfaces
Can you please explain how to generate a nth degree Bézier/Bspline curve using a set of points in Rhino-python? If it’s achievable, I’d also like to know the process of creating a Bézier/B-spline surface using these curves.
I tried with degree two:
Screenshot 2024-04-14 at 8.03.20 PM
import scriptcontext as sc
import math
import System
import System.Collections.Generic
import Rhino
import Rhino.Geometry as geo
#Define the control points
points = [ geo.Point3d(0, 0, 0),  geo.Point3d(1, 1, 0),  geo.Point3d(2, -1, 0)]
bezier_curve = Rhino.Geometry.BezierCurve(points)
sc.doc.Objects.AddCurve(bezier_curve.ToNurbsCurve())
you need to define the points as Point3d - not as pure arrays of numbers.
Hi Tom,
Thanks for the answer, I ran your code and still getting the same error message.
Hey,
import Rhino
import Rhino.Geometry as rg
# define point3D points
control_points = [
    rg.Point3d(0, 0, 0),
    rg.Point3d(5, 10, 0),
    rg.Point3d(10, 5, 0),
    rg.Point3d(15, 0, 0)
curve = rg.Curve.CreateInterpolatedCurve(control_points, 3) # create interpolated curve
#Rhino.RhinoDoc.ActiveDoc.Objects.AddCurve(curve) # add interpolated curve to rhino
bezier = rg.BezierCurve.CreateBeziers(curve) # create bezier curves
for segment in bezier:
    Rhino.RhinoDoc.ActiveDoc.Objects.AddCurve(segment.ToNurbsCurve())
If you want to work with Bezier curves you could also translate an interpolatedCurve into bezier curves.
