If you perform a bevel (SubD) on the red edge, the object is destroyed.
Because?
Bevel on edge red destroys the object.3dm (199.0 KB)
I’m seeing this work in Work In Progress
(7.0.20189.12055, 7/7/2020)
Commercial
I know, usually the bevel must be done all over the edge … but I meant a portion of the whole edge, only the one where I put the annotation point … If you try as I tell you it doesn’t work (only on that edge portion).
so… because the bevel adds 2 edges it tears the singularity apart-
BUT…
you can simply grab all those points and stitch to collapse them back into a singularity-
then I took the liberty of un creasing the result which returns it to a smooth subd.
You can then start re-creasing or beveling or…
just continue along with the smug knowledge of your own 3d modeling awesomeness.
