Between OSnap option location
Looking for the between option in rhino 8. I used to be able to be able to hold ctrl + shift and it would show up in the osnap bar. this is no longer a thing in rhino 8.
I have been able to just type between but its more keys when doing commands
Mouse over Osnap bar. Press and hold Shift key (without Ctrl key). The set of Osnaps which include Between appear.
Added: In V7 if you are over the Osnap bar and holding Ctrl down, then press Shift the set of Osnaps which include Between appear.
In V8 if you are over the Osnap bar and holding Ctrl down, then press Shift nothing happens. You need to let up on the Ctrl key for the set of Osnaps which include Between to appear.
