Beta toolbar edit warning message a bit disconcerting
Just opened to check something, didn’t change anything. then clicked the Cancel button
But the warning makes me nervous that I might have accidentally messed something up without realizing.
Ok, and another problem here, if I click Yes to the discard message, the following pops up - sometimes.
This warning shouldn’t show if you didn’t change anything (so possibly a small bug).
Using your set up I don’t get this issue, so let’s gather some more info
  1. How did you show the dialog?(command, edit icon etc)
  2. Is that Main toolbar from the default.rui?
Hey Callum,
I’m in classes this week, so sometimes it takes me awhile to respond.
I just shift+right-clicked the button to open the button editor just to see what was behind it, then hit the cancel button - then the message shows up.
Hmm, this is weird. What is open and docked to the left is the MainCustom toolbar which is indeed in default.rui. However, what opens in the middle of the screen after closing the button editor is named Main 01. That doesn’t exist anywhere I can find… Seems like it is making a copy of Main which does exist in default.rui. It appears only to happen the first time after opening the Beta. I just checked now and it happened again. And yes, I have the latest - 9.0.26286.06303, 13/10/2026
Screenshots:
Clicking on “Properties” above shows me this:
What is actually docked on the left side is this:
There is something very bizarre going on here in the Toolbar window.
This is what my C:\Users\<me>\AppData\Roaming\McNeel\Rhinoceros\9.0\UI folder looks like:
It has the default .rui’s plus my custom .rui’s. The first two v8custom1 and _copy are the old messed up ones, the v8custom-tov9 is the one that works. I don’t want the other two, but it seems the Toolbar function is designed to simply show (Open?) everything in that folder. Running Toolbar shows me this:
So, from inside Rhino I tried to close the the two I don’t want. See the video below, someting is cross-wired. I close the bottom one v8custom1 using File>Close, but it is indeed the top one v8custom-tov9 that closes. :face_with_crossed_out_eyes:
I can certainly delete the old ones from the UI folder. But wanted to show you that there is still something hooked up incorrectly here.
