Best way to test if two curves are tangent?
But how would you be sure that your curves are in the correct order?.
Without the correct order how is it possible to compare a angle?.
Splitting the curve at a specific value later is a better way to go.
You could use the same logic from this thread but instead of culling just split at the false and not the true member
