Hi, Jeremy, oooh thanks for the link, will ring him in the morning.
That’s a Post War tread pattern and better than the modern HS treads (hand size), the rims are the same.
Which type of trolley, The Type B, Type C and Type D as well as the Type F all used these 18 x 7-8 tyres. Though in WW2 they just had 18 x 7 on the walls,
Dia of wheel supposedly 18inch from those markings.
Measured from Photogrammetry 16.3 though inflated to 20psi and not 40psi, as may go bang he says.
6 inch inner to outer rim edge he measures, my CAD was 6.315
CAD/Photogrammetry has 10.1097 for rim dia but getting it measured on a real one.
the scaling down to get 6 from 6.315 would give 9.6 but I recall at least 10 on those over the years measured. I have site notes to dig out.
My ruler method is very carefully done, and I have at least two cooking at the moment !
rim thickness 0.25inch.
I am using Metashape standard, (or if it fails to align all Photos then Photoscan which invariably aligns all, then continue in Metashape)
and laid into the many photos as a secondary smaller photoshoot, same focal length etc etc, is a ruler.
I marry that chunk in Rhino to the first chunk, rather than use Agisofts chunk aligning., which I have yet to get to work !
Orient3Pt then scale if need be. turn layer on and off and see a good match.
Run a section through the ruler , divide 30 then line through points, and with both meshes grouped orient that line horiz, then scale the meshes to the ruler, then use sections on rim to re orient the rim ortho etc.
Steve
( I am the UK expert and co-ordinator on WW2 RAF Ground Eqpt)
