Hi
V5
I need brown outline as I am using for all my bricks (on layer ‘bricks’ colour brown) but some need a violet fill (or hatch in Rhino terms)
What is best method to fill some with violet hatch using hatch command ?
I cant see anything in help on this.
I need to be moving the filled one about so thoughts of two layers one violet the other brown sheds doubts over this.
V5
I cant see where to do that, I select the hatch which is on my brick trace brown layer, and go properties
I have
display colour
Linetype
Print colour
Print width
I select lavender as display colour but the hatch is still brown when done.
Hello - are you saying that you select a hatch object and in Properties change its display color and the color does not change? If so please export that object to a new file and post it here.
