Hi guys!
Anybody knows what’s the better for Revit, GeForce or Quadro?
Thanks
Hi guys!
Thanks
Revit uses DIrectX, so the GeForce should get you a better cost/performance ratio.
You will try asking in Autodesk forum. But how I know the autodesk cooperate with Invidia Quadro.
Thank you, that is great info.
Hi Holo.
I have only ever used the Quadro cards (and the only card certified by Autodesk)
If you want to research via a forum, try www.revitforum.org rather than the Autodesk forum.It is independent from Autodesk and very resourceful including hardware recommendations etc.
Barry.
Thanks, but I leave it up to the customer. They are building new machines to work for Revit, AutoCad, 3DS max and Rhino. And it seems Rhino is the only one struggeling with OpenGL and drivers… Both on quadro and geforce. I’ll let you know how it turns out.
