I had a model last night that was spending 15-20 mins by going from wireframe to shaded, im using the new version V7 latest update, I did update the graphics driver through this fault finding. I used selbadobjects and extractbadsrf which didn’t show anything on the affected model. Managed to find the surface by deleting a few sections off the model, then deleting the layer that they were on. At the time i had extracted a selection of surfaces then started to edit so the original model wasnt ruined.
I then asked myself if the surface was in the main model how was a going to restore the backup if i couldn’t find the affected surfaces / objects?
At the moment i’m backing up sections of the model in layers. I cleared the above error by deleting a layer that i had set for Edit. I suppose i could have hidden each layer to narrow down the badsurface / extractbadsrf which wasnt showing up on the command.
Is this the preferred method of backup, copying sections of model to layers? or copying the whole document as a duplicate? I could then delete the duplicates as i go along. Seems a bit of a faff.
Hi -
I frequently use the IncrementalSave command and delete “old” geometry in the current file. That way, the current file is as light as possible and you can always go back to a previous version if that were to be necessary.
I append my file names with two or three digits. I periodically Save while working, and after a significant amount of work I Save, then SaveAs and increment the file name. Then when I can backup when I discover a mistake or flawed modeling method. Also I use Worksession with reference geometry in a separate file which does not need to be saved and backed up since it does not change.
Example:
SaveAs Boat001
Save
Save
Save
SaveAs Boat002
Save
Save
SaveAs Boat011
Save
SaveAs Boat012
Save
Save
SaveAs Boat101
and so forth.
Thanks very helpful. I think you just need to have an organised routine . To easy to loose focus and get carried away. Routine is the key I think . Thanks for you input
I know I’m being picky, but these are not backups: they are copies or snapshots. A backup is a copy made from your machine to another environment, ideally in a remote location, so that should your hard disk die, your laptop be stolen, your premises burn down, etc, you can recover your work to within a short space of time before the disaster.
I only make the point as I don’t want people thinking that because they’ve done an incremental save, they can tick the “backup taken” box.
